Hi,
After a long search for a kit to convert my central locking to key less entry, that came with a flip key, i finally found one, then after a long wait i finally received it, however as its a universal kit, the instruction are pretty poor.. And by instructions i mean there are none.. however it does have 4 Diagrams.. One is just for windows automatically rolling up, lights flashing, shit like that. Then there is 3, which im guessing only 1 is for my car, They are labeled "Positive trigger, Negative Trigger, Positive and Negative Trigger" Ive been told the supra is negative trigger? I also need to know where the "Central locking system" is located, and what wires are for lock and unlock signal? Here is a diagram that was supplied for negative trigger ![]() |
Depends on the Model. For the MKII Supra, I believe it is in the drivers side kick panel. Here is a link to the manual that shows electrical connections. http://www.cygnusx1.net/Supra/Librar...aspx?S=BE&P=68
Where did you get the lock kit, I'm interested! Cheers, Brad |
central locking relay | theboy641 | MKIV Supra | 0 | 01-20-2010 03:45 PM |
Factory Keyless Entry | suprajim | MKIII Supra | 1 | 11-04-2009 02:54 AM |
Body Conrol Module + Keyless entry kit help? | FL850 | MKIII Supra | 0 | 09-28-2009 09:24 PM |
how do i make the hatchback keyless entry work? | ogkush | Non-Generation Specific Questions | 6 | 02-21-2006 11:18 PM |
central locking | kixxx | MKIV Supra | 1 | 01-05-2006 02:22 PM |
