Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 06-13-2007, 07:21 PM   #1
finaltable
finaltable is on a distinguished road
Default Anything special I need to know about the Mk 3 wiring
At lunch today I figured out how to remove the rubber cover around the head unit and plan to replace the double DIN with a console pocket/single DIN unit this evening. Is there any kind of proprietary wiring connection back there I will need to worry about before I do this? I'd like to finish it in one session if at all possible and would like to have some idea of what I am about to face BEFORE I rip the dash apart.
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
Old 06-13-2007, 08:35 PM   #2
dannydavi
dannydavi's Avatar
on my 86.5 mkiii i needed to get the lil wire connector set that converts from the old model cars to the new model stereo units... it was like $5-12 at wal-mart or kragen auto. and none of the colors matched up so make sure you read what each wire is, they are clearly labled. also i would use electrical tape to do the connecting, i went crimps the first time around and didnt have a good connection, good ol black electrical tape substituted in got it done. also the in dash installation kit i purchased from a kragen auto parts store did not fit perfectly, i had to cut some dash rubber/plastic out... but, maybe that was just that one brand i got, i've heard others had no problems. good luck.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 06-13-2007, 09:04 PM   #3
finaltable
I hadn't thought about the adapter kit. The last two times I've done a stereo swap I've replaced a DIN with a DIN. Since the console pocket I bought is DIN sized I just assume the two would just slide in. I have a feeling I am going to be pulling the current head unit out and putting it back in tonight so I can see what I need to get to finish the job.
Old 06-14-2007, 01:26 PM   #4
finaltable
Okay, I got the radio out last night. The head head unit has two white proprietary connectors on the back and two other wires. One wire is clearly the antenna; the other I'm guessing is the power antenna actuator.
I am guessing I could just pull all the wires out of the plastic modular connected but I don't know which wire is which. I'm also confused about the fact that the Supra has 6 speakers, something I don't believe most head units can drive out of the box.
Wiring diagram? dannydavi MKIII Supra 3 04-07-2009 04:18 AM
1jz extended wiring harness duece212 MKIII Supra 0 02-07-2006 10:03 PM
HKS VPC wiring diagrams cat007 MKIII Supra 0 11-07-2005 09:28 AM
