#1 | |
![]() Quote:
RMS stands for Root Mean Squaired. to put it another wat that is the constant power the amp produces. the max is the power it can produce at any given time but the actual power rating you want to look at is RMS Take it from me i am MECP advanced certified! |
#2 |
Check it out. if you series speakers together you will raise the ohm load (4ohm + 4 ohm =8ohm) parallel (4ohm +4 ohm = 2ohm)
"mono block" amps are 1 ohm stable, with the lower the ohm load the higher the power produced. so to answer your question you need to find out 1 how many subs you want 2 are they dual or single voice coil after that calculate ohm load to see if you purchase the 2,4 or 8ohm subs |
#3 | |
![]() Quote:
Audio and a lot of other things wrong with car | bluemeate | MKIII Supra | 4 | 05-18-2010 07:07 PM |
ohms rating for factory speakers | whowouldfigga | Car Audio and Alarms | 0 | 04-13-2008 07:01 PM |
Sensor ohms | Metalshredder_25 | Non-Generation Specific Questions | 3 | 09-27-2006 04:03 AM |
audio for 87 supra | y8Dgr8 | MKIII Supra | 5 | 07-09-2006 12:30 AM |
