Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Drifting
View Poll Results: is it hard to fis a head gasket ?
yes 1 100.00%
no 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 06-02-2010, 03:02 PM   #1
javier medrano
javier medrano is on a distinguished road
Exclamation 88 non turbo supra
i have been trying to improve my torque on my 88 supra but i dony know what to put so it can have a higher torque so does anyone know what i can do?
javier medrano is offline   Reply With Quote
Old 06-02-2010, 05:20 PM   #2
TripleC
TripleC's Avatar
Nothing inside the engine is just goingt o be a walk in the park. The thing is... You will most likely find other things that our broken,damaged or things needing replacement once you start pulling the motor apart.
good luck
Old 06-08-2010, 02:56 AM   #3
turbonicsperformance
try a few different setting with your cams get a set of adjustable cam gears set your ignition timing a little advanced though not much make sure you have a good working cooling system try an electric fan and a cold air intake a set of headers if your actually looking to build the engine you could do high comp pistons lightened flywheel and one piece shaft none is cheap but it all helps
Tags
88 supra, emergency, performance, speed, torque
Information about non turbo Supra Jimbo_2JZ Non-Generation Specific Questions 3 02-20-2009 10:13 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
HorsepowerFreaks Turbo M3 vs Single Turbo Supra ChrisB Non-Generation Specific Questions 0 01-01-2007 04:56 PM
