look everybody lets jsut end it before we reach 1,000 pages, FRONT WHEEL DRIVE CARS CANNOT DRIFT think about drifting is sliding sideways around a turn, can front wheel cars do that? no they would grip unless u have alot of HP and bald rear tires so you could slide but still i have never seen a front wheel drive car drift around one turn. if it was a S turn then they can do that cuz it would the car would whip in the other direction and be able to slide at the end of the S turn. Anyway just my opinion. :bigthumb:
I think I've done it on accident... Or maybe that was more of a powerslide,
Or a peel-out while already moving. What I did was just hit the clutch while in a turn and coasted while rounding the corner, then I gave it a little too much gas as I let it out and surprise I wasn't moving where I was pointing. I don't know about drifting. I also thought this car was too heavy for that, atleast without turbo, so it is quite possible that I did something else. For the record, my car is an '82 5mge mostly stock from what I can tell. My suspension is CD-Skipping, Soda-Spilling, Teeth-Grinding stiff but it's great at cornering. My question for you sidewinders is about interiors. I heard the key to getting sideways is losing weight. My interior is thrashed and I'm looking for stuff to restore it. Anybody want to make a couple bucks for stuff you don't want lemme know. Like I said, I have an '82. She's an L-type with burgundy interior. My plastic is chipped all to hell, the vinyl on the dash is sunbaked and I could use some new carpets. You wanna get rid of any of this stuff? Lemme know. Thanx -B |
by ur description Quote:
and im still able to drift with the car if skylines, mustangs, chargers, can do it, and those are heavy cars our supras can too even without turbo they got n/a ae86 corollas, drifting against s15's , vipers and big hp cars it all comes down to technique and how well do you know your car's capabilities, and your boundaries as a driver too |
The problem with supras is steering angle. The wheels dont turn enough. Everyone says the key to drifting is steering angle :)
maybe pull on the ebrake a little more harder maybe a little more gas here and there we'll see what we can get lol |
u can put spacers on the inner end of ur tie-rods. this should give you about 10% more angle. i think the machined spacers that they sell for 86's fit our tie rods, but any properly sized spacers/washers should do the trick. the spacers i have are for a corolla. they're about 5/16ths of an inch thick
industrial parks are the way to go mang
today i stole my own supra and tryied just to see if my e-brake worked and for some reason i barly felt it brake. how would you go about fixing that?
its not a bad idea if its a weekend car but that will eat up tires unevenly and like isph said it'll mess up the alignment |
