Old 01-06-2005, 04:32 AM   #1
das
das is on a distinguished road
Hi all,
Just need some quick advice, I have seen on some websites supras that have a different heater control panel to mine, my one is the standard thing ( slide the knob along to get more heat lol ). The ones i have seen do look exactly the same size/shape etc but have a small digital disply and are push button adjustable. The 2 questions i have are these lol
1. Can the digital style controls easily be put in a mk3 with normal controls
2. Does anyone know what particular supras i can find these on.
Thanks again
das is offline   Reply With Quote
Old 01-06-2005, 08:26 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
LOL
i've been thinking the exact same thing
jdm supras get the boring slide ones but the usdm spec ones get the fancy digital ones
i'll check it out and see if it'll work
Pics of my build.
Do a diagnostic first!
Old 02-23-2005, 12:57 AM   #3
Supra Guestobrut89
Guest
Posts: n/a
it depends on the year of your car the 86.5 and up has the digital push ones but if you really want a nice one youll want to go with the 89- 92 model its so much sleaker
Old 04-06-2005, 05:03 PM   #4
dbrooker
dbrooker is on a distinguished road
hey,
Unfortunatley I think you have to replace the whole HVAC unit to automatic climate control to use the digital unit. There is a sensor in the middle of the dash that will detect the heat close to the window. When in auto mode it will automatically adjust blower and fan speeds to heat up to that specified temp. When desired temp. is reached it will slow the fans right down and maintain that temp.
You may be able to hook the unit up as long as the harness and prongs are the same, but you won't be able to use the automatic mode unless you have the sensor and wiring for it.
dbrooker is offline   Reply With Quote
Old 04-06-2005, 06:21 PM   #5
das
i have the 88 non turbo and even without the digital controls it still has automic controls so i would assume this function would still work the same
Old 04-08-2005, 10:19 PM   #6
monkihead
SP58GT
monkihead's Avatar
my 85s had slider controls and the auto feature. my 89 has digital pushbutton auto features. are you sure they are supras?
monique- better off dead
Old 04-12-2005, 09:53 AM   #7
das
am i sure what is a supra, My car ?. Last i looked it was lol
As you have just said yourself your 85 had slider controls AND the suto feature and as thats the bit we were talking about then whats the arguement lol
Old 04-12-2005, 09:40 PM   #8
monkihead
SP58GT
monkihead's Avatar
oh, i mis-read. i didnt know that some supras didnt come with digital controls (87-93s). id figure they'd still work. one just uses an electrical signal to switch between the vaccum lines in the back.
Old 04-14-2005, 08:42 PM   #9
das
yeah i hoping if i can finally find one of the digital controls that i should just be able to plug the thing in but i'll never know if i cant find one lol
Old 04-14-2005, 10:14 PM   #10
monkihead
SP58GT
monkihead's Avatar
have you tried junk/salvage yards?
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Heater hose locations suprabahamut MKIII Supra 4 12-16-2008 10:07 PM
Heater Question 87 Supra lobosupra MKIII Supra 3 12-11-2008 01:51 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater By-Passing...Your Thoughts mrnickleye Non-Generation Specific Questions 2 05-03-2006 03:06 PM
