#1 |
HPF
I've been talking with D2 about making some MK3 coilovers and they have finally agreed. I just need 3 people to step up (and one person to donate their stock suspension). These will retail for $1250, but if you get in now your cost will be $899!
![]() * 36-way adjustable dampening (rebound and compression) * Made from high quality 6061 Aluminum with T6 for increased hardness * Compression/Rebound adjustable * Adjustable spring perch for height adjustment * Adjustable body allowing maximum suspension travel * Pillow Ball Top Mounts * Monotube High Pressure Design * Electroplated body for protection from corrosion and rust * You can specify spring rates upon ordering The downside is that these will take ~6 weeks from the time I get the last payment in, so don't plan any races around these quite yet. |
#2 |
how hard is it to adjust them
91 N/A automatic supra;K&N FIPK;2.5" custom exhaust;no cat;pacesetter header;eibach springs;tokico "blues";MKIV TT rims |
#3 |
HPF
Comparable to other coilovers. When you're adjusting the ride height, it may take ~40lbs of effort to turn the spring perches. Adjusting the dampers is easy (twist of fingers).
#4 |
Anyone signed up yet? What will the weight be compared to say TEIN or HKS?
Thanks Rich
#5 | |
HPF
![]() Quote:
Thread Tools | |
Display Modes | |
