Old 10-31-2007, 03:06 AM   #1
dom747
dom747 is on a distinguished road
Default 7mgte
hey i am doing a 7mge swap to a7mgte....and i was wondering..the car i have with the 7mge in it is a 86.5...will any 7mgte engine fit in there??? becasue ive read that you have to watch for the yr of cars?...just want to clearify b4 i buy any 7mgte engine then it not albe to work in my car...aslo the 7mge is a usdm engine ...would i be able to use a jdm engine???? cause i found a site that has engines that come with everything....but they are jdm? is that ok?
dom747 is offline   Reply With Quote
Old 11-01-2007, 06:43 PM   #2
supraman121
Do you have a second gen or a third gen supra? I have a mid year 86 supra that is an mk3 or third gen, If you get a 87-88 7mgte motor it will fit with no modifications to the engine bay, the trans will work but you will need a new clutch if you dont upgrade it when the engine is out, you'll also need a ecu from that year and a wiring harness uncut if you can find one.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 11-02-2007, 03:49 PM   #3
Supra2NR
Supra2NR's Avatar
If you get a 86.5-87 motor
Be sure to get the same year
Ecu and harness
88 has a bit diffrent color combinations since it was year they were making slight changes to the mk3
88-92 motors came with the similar mounts to the jz series motors
Also diffrent harness and ecu
Any turbo trans should bolt up to any year motor
But I suggest getting an 89 motor, and jus replace the mounts since they use the genuine 7m crank
Instead of the 6m that the pre88's use
U would also need coilpacks
And igniters
And the power steering reservior is diffrent in the turbo motrs
And u should post this on the mk3 section
And yes it would bolt right in with no fitment issues
Old 11-03-2007, 03:40 AM   #4
supraman121
Ecu and harness
And igniters
89-92 is when they changed the engine mounts to acomidate for the 1jz engine, so an 87-88 is very similar the color combination is going to be the same.
K&N Air Filter
Old 11-07-2007, 04:38 AM   #5
dom747
Default ok...another question
ok soo i found this site where i could get a good jdm 7mgte engine...but it says there engines are from a 89-91 supra....will that engine fit into my 86.5 car????....( the engine comes with the cut wire harness...and ecu..and everything)
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
