Old 11-08-2007, 01:49 PM   #1
super7m
super7m is on a distinguished road
Question can you blow a motor with a turbo
someone told me if i had a turbo on my car it would blow up.
super7m is offline   Reply With Quote
Old 11-08-2007, 02:49 PM   #2
Wink
The problem with just adding a turbo to a non-turbo engine is....you will like the added power, boost it more and more, race it too much, until the motor can't handle the extra stress. Then......boom !
Old 11-08-2007, 03:31 PM   #3
super7m
so what do i have to do so that doesnt happen
Old 11-09-2007, 01:40 AM   #4
I don't turbo mine for the reasons I mentioned earlier. The ONLY reason to turbo is to get more power.
When you get that, you will use it. Then, you will blow it up.
Old 11-15-2007, 08:12 PM   #5
OfnaRcR
you are discouraging a potentially awesome build. Who knows, this guy could have a bunch of money and might decide to build the motor to handle it.
When you turboing a non turbo engine there are many things to look at. Basically you will want to rebuild it stronger. I'll let you read up on that because it is too long to explain and their are pleanty of good write ups on how to build an na to handle a turbo.
Old 11-16-2007, 03:27 AM   #6
Wink Money
So if you Re-Read my first post, you will see the words "with just adding a turbo to a non-turbo engine". Most people with "enough" money to spend on there car will get a turbo block to build.
And 95% of the people that have an N/A MKIII don't have lots of money to throw at it. Do you? And if so, let us know what your dyno results are after you've spent, say $8 k on that motor.
Old 11-17-2007, 04:59 PM   #7
OfnaRcR
I wouldn't know, i don't have an NA.
Old 11-19-2007, 07:13 AM   #8
amdrift
amdrift is on a distinguished road
you'll either throw a rod, break a ring, crack a piston, crack the block, crack the head or blow a gasket. those are just a few possible things that will happen if you slap a turbo on n/a motor.
amdrift is offline   Reply With Quote
Old 02-10-2008, 10:10 AM   #9
peedamonkee
peedamonkee is on a distinguished road
if you have the right setup. the car should be good as a daily driver. i had a mkll with 6m swap added boost. all i did was ad 3mm hks head gasket. and external fuelpump. at 15psi. an she ran like a dime. the only thing that went out was the main bearings. i was racing every weekin drove it to all the race tracks.. for 2 years. for my setup was around a grand with the motor... so just have the right setup an its on like donkey kong.....
peedamonkee is offline   Reply With Quote
