Old 01-15-2008, 06:24 AM   #1
SupraMike
SupraMike is on a distinguished road
Default Heat Issues
I have a black 85 Supra, for some reason or another my heater isn't blowing out of the vents. I can feel hot air coming through the vents but it doesn't blow when I have it on fan turned to it's max. I am not sure if it's a blown fuse, heater core of if it's the thermostat. Any help will be great as I am freezing in this Washington weather.
SupraMike is offline   Reply With Quote
Old 01-16-2008, 03:02 AM   #2
SupraMike
Default Fixed heat issue
Found out the issue to my heating, it turns out it is the blower motor.
Old 09-18-2008, 06:59 AM   #3
jrok
jrok is on a distinguished road
Default hey
the blower resistor could be the problem and or fuse
1984 celica supra with 7mgte swap, custom intercooler, 2.5 exhaust no muffler or cat, shimmed wastegate to 12 lbs boost, with r154 turbo 5-speed tranny 16x8 xxr s13's with 245/50R16 toyo proxes 4's
.http://au.youtube.com/watch?v=rgOxP0PxCwo
.http://au.youtube.com/watch?v=uf989mb3EDw
also own:
2000 4runner 3 inch lift, 33inch tires
.http://au.youtube.com/watch?v=J15k1rCh7-A
1988 4runner stock
.http://au.youtube.com/watch?v=2u7e1_pMqfs
.http://au.youtube.com/watch?v=9lu4j5P6M7M
jrok is offline   Reply With Quote
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
IC pipes and heat wrap questions. redmaro MKIII Supra 0 09-26-2007 08:00 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
heat getting into car sd88supra MKIII Supra 7 11-03-2006 12:47 AM
