Old 04-15-2006, 02:40 AM   #1
8222RSUPRA
8222RSUPRA is on a distinguished road
Default 22r Supra
Ive Just Got A 82 Auto Supra With A Butcherd Engine I Plan On Autocrossing Drifting And Genral Mayheming The Car I Was Thinking Of Swapping In A 22r Supercharged With Mechanical Injection On Alchohal I Have All The Parts Nessasary Including A 5 Speed It Is Only 40-50 Hp And 30 Ft Pounds Less Then The 5mge Stock To Stock The Motor Would Be Good For Aboat 250-300 Hp At About 8-12 Pound A M-60 SUPERCHARGER 85 MM THORTALL BODIE Would The Weight Loss And Wieght Distubution Be Worth It? Any Ideas?
8222RSUPRA is offline   Reply With Quote
Old 04-27-2006, 05:47 AM   #2
hangsupra
i not so sure... but i cruze around on the net here...i found out this one yellow mk2.... with a super-charge.... but i forgot to save the link... n i blow it... cause i still looking for one too but not so sure tho... cause i saw one but sounds pretty good but dont really know how they do it... n i cant find the page again.... what a whack of me....
Old 07-29-2006, 01:21 AM   #3
canamyth
canamyth's Avatar
canamyth is on a distinguished road
have u thought about using a 22r block with a 20r head to raise the compresion ratio? just a thought
canamyth is offline   Reply With Quote
Old 07-18-2008, 07:31 PM   #4
roys88supra
roys88supra is on a distinguished road
if you're going to supercharge it don't increase the combustion ratio too much or you will blow the head off the top of the block. I watched a guy do that with a massive charge of nitrous. he litterally blew the head off the block, the timing chain is the only reason it didn't go through the hood. personally I would go with a 2.7l taco motor instead of the 22-r engine. it has a better torque curve and has a toyota supercharger available. whats nice is a lot of the rock crawling guys have built a stand alone harness for the 2.7 all you need is the ecm and the engine, they will supply everything in between. hope that helps. B.T.W as soon as I build the funding back up I'm going to put a 2.7 in my 1985 4-runner so if you need any of the links for the wiring harness just let me know an I'll hunt em for ya.
1988 targa, white, 5spd N/A. but not for long
roys88supra is offline   Reply With Quote
