Old 11-06-2008, 12:12 AM   #1
bigtime337
bigtime337 is on a distinguished road
Default 86 supra MK II no heat
The automatic climate control hasn't worked in years, was stuck on high heat which was fine. Not I get little or no heat and winter is Coming. Already changed the thermstat and topped up the rad but no change. recently installed an inline block heater. Heard could be air trapped in the heating core??? I think maybe the hot/cold mixing valve has shifted toward cold. Anyone know where that door is and how to reposition it? Any other ideas would also be appreciated.
bigtime337 is offline   Reply With Quote
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
need help supra over heat 91_7mgte MKIII Supra 9 06-08-2006 10:43 PM
