Old 02-05-2009, 12:27 AM   #1
84supradude
84supradude is on a distinguished road
Default idle stuck
so i cant lower my idle lower than 1500 and i need it at 750. a little while back i didn't start my car for about 6 months and it idled at 2500 so i lowered it to 1500, i think something is stuck but donno what. it is an manuel 84 celica supra
84supradude is offline   Reply With Quote
Old 04-08-2009, 01:10 AM   #2
suprabahamut
Have you looked at the ignition timing with a timing light? If it is high it could be the problem.
Old 04-08-2009, 02:49 AM   #3
midwestmk2
midwestmk2's Avatar
I would also consider checking the inside if the throttle body..Some times build up of crap will cause it to stick open more than normal causing a high idle..Im also seconding the timing mentioned before..
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
