Old 03-04-2009, 03:29 AM   #1
Lost209
Lost209 is on a distinguished road
Exclamation 7M GTE swap into A MKII...What Will I Need
i have a 85 MKII and the engine just froze i was thinking of droping the 7mgte into it what will i need to do all that other than the engine complete.
JDM ENGINE 7MGTE TURBO SUPRA 87-91
Lost209 is offline   Reply With Quote
Old 05-10-2009, 11:56 PM   #2
suprabahamut
You will need a ecu probably, get a engine with a replaced and right torqued head gasket. Get a clutch kit and new seals for the engine and transmission. There might be more somebody else will probably add what I left off.
Old 05-13-2009, 02:47 AM   #3
midwestmk2
midwestmk2's Avatar
unless you have previous experience with doing an entire engine swaps like this(ie=ECU,custom harness,cooling,money,time,and tuning) i would just have the 5m rebuilt..You can always convert the 5m to a turbo later if you still want to go boosted.. It is easier to convert it than it is to swap a 7m in there..If you do go 7m good luck on the swap and ill answer any questions if i can..
1jz swap 87-POSupra MKIII Supra 4 10-27-2008 03:34 PM
questions before I begin my swap 2dogs MKII Supra 1 09-18-2008 05:49 AM
mkII common problems..and swap?? the_trooper08 MKII Supra 0 09-04-2007 02:11 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
