Old 07-25-2005, 11:53 PM   #1
Graeme
Guest
Posts: n/a
this kinda just started, i got o a place near here and there is quite a lengthy hill i have to go up, its a gradual slope and after a little while i can smell something :S im not sure how to discribe it, almost like a mix between burnt clutch (mines supra is an auto) and burning oil or soemthing :s. im nto sure what to check ir what to do i have checked the engine and transmission fluid but they are ok, i just need to change oil in a month or so. Any advice would be greatly apreceated.
Old 07-26-2005, 04:23 AM   #2
Poodles
Poodles is on a distinguished road
Lengthy hill.... under load your turbo (if you have one) will be working quite a lot, that and your tranny. Keep in mind tranny fluid is annoying, and depending on how hot it is, it expands a LOT.
There are a lot of things it can be, just start looking for leaks. Also you didn't mention if it was overheating at all, as it could be that, but I'm thinking it's the tranny :unsure:
Poodles is offline   Reply With Quote
Old 07-26-2005, 01:47 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
good suggestions
try the above, check fluid levels of all... check for all leaks.. oil, water, trannie
make sure the fluid side of the car is happy
are there any other symptoms?
is it when the heater is on? or do you smell it coming in from outside?
Pics of my build.
Do a diagnostic first!
Old 07-26-2005, 11:16 PM   #4
Graeme
Guest
Posts: n/a
no heatter, its usly hot out and i have the window open. It not a turbo so wouldnt be that, well it cant be because i dont have one heh. but yeah il check for leaks. It already leaks a bit of engine oil but i check that like every week atleast so its ok. hmm it doesnt seam to be overheating, the smell seams to be the only thing that is happening, oh yeah and its not under load when it does it. thanks for the sugestions
Old 07-27-2005, 01:11 AM   #5
SuperSupra86
SuperSupra86 is on a distinguished road
Hmmmmm....Well its probably tranny going (I've burned a few hehe) but check the HG for good measure....i know MKIIs aren't known for blowing them but could be....
Who needs zoom zoom......I got turbo!!!
SuperSupra86 is offline   Reply With Quote
Old 07-27-2005, 06:17 AM   #6
monkihead
SP58GT
monkihead's Avatar
or tranny fluid may leak from the tail on the up hill, dripping across the exhaust??
just my 2cents
monique- better off dead
Old 09-22-2005, 05:03 AM   #7
fire0fear
fire0fear is on a distinguished road
i may sound stupid here but i got a strange smell, basically after i come to a stop from floorin it or anything pushin it i smell somethin of sewage kinda, im 90% sure its just xtra unburned gas since most old cars smell bad when u punch em but anyhow, just if thats what your smell is then dont worry about it its normal, i guess
fire0fear is offline   Reply With Quote
Old 09-24-2005, 11:01 PM   #8
hangsupra
Talking
well back in the day when my still auto. i use to have that problem... but after all i swap from auto. to manual now i dont have no more. my old one the problem is that the trainny leaking from the rear end cell n the side where the shifter and the adapter cable where the speed cable goes from the trainny to the dash board. when you speed for awhile or drove for a long distance. especially when you drove on the high way for couple hours for non stop from towns to town. when i make a stop sometime it smoke from the bottom of the car from the trainny when it smoke like that get off road n look under neath the car. trust me you see lots of trainny flyid everywhere underneath the trainny especially the converter.... check that first see if it do it. well let me know if this help you little bit.
have 2 strange problems on my 87 non turbo supra 87supram Non-Generation Specific Questions 3 09-10-2008 07:44 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
