Old 07-15-2009, 04:48 PM   #1
GL4CI3R
GL4CI3R is on a distinguished road
Default Engine takes way too long to start
Hi there Supra fans.my 82 supra is takin way to long to start up. i already changed the fuel pump. the engine seems to be in good shape. and the car was running well about 1 year ago and i left it standing for a long time. any suggestions? thanx
GL4CI3R is offline   Reply With Quote
Old 07-17-2009, 04:37 PM   #2
midwestmk2
midwestmk2's Avatar
Bad gas,Clogged filter,Bad coldstart injector or temp sensor that tells the cold start to fire..mine did the same thing about 2 years ago..I just bypassed the cod start injector and hard wired it into a switch that i can turn off and on..Now anytime it acts like it wont fire up at first i just turn the switch on and off once or twice and then fire her right up..
Help Engine cranks but wont start supra210 MKII Supra 1 05-30-2007 12:46 PM
Start up and engine dies. Drag0na5h MKIII Supra 12 01-14-2007 02:04 AM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
How long does the engine last? ShAuN MKIV Supra 1 01-18-2006 02:01 AM
Engine still wont start 87 supra 7mge lilsmitty MKIII Supra 12 01-12-2006 10:53 PM
