Old 07-30-2009, 07:51 PM   #1
Nikukun
Nikukun is on a distinguished road
Default Alarm goes off when i open my door...
After i lock the car and set the alarm, EVERYTIME i open the door to get back in it goes off till i put the key in the ignition. its kinda annoying, is there anything i can do? short of cutting the alarm cuz i dont wanna get rid of the alarm all together...just everytime i unlock it... plz help!
Nikukun is offline   Reply With Quote
Old 07-30-2009, 08:18 PM   #2
gmansupra
gmansupra's Avatar
gmansupra is on a distinguished road
depending on the year (one of mine is an 85) that seems to be a factory hiccup that you lock the door hold up the handle and close the door to set the alarm. Unfortunatly when you unlock the door the alarm does not delay. I have not found that there was ever a delay set. Just have to be quick getting to the switch to cancel it. sorry couldnt help.
gmansupra is offline   Reply With Quote
Old 07-31-2009, 06:39 PM   #3
Nikukun
oh ok, yea mines an 85 and its just embarrassing that my alarm goes off everytime i open the door...
Old 08-01-2009, 02:47 PM   #4
gmansupra
gmansupra's Avatar
if you close the door then lock it w/the key it wont set the alarm. then when you want the alarm set just lock it inside then hold the door handle up. even then mine has gone off a couple of times. dont know why unless someone tried to open the door or maybe just gremlins.
1985 project 1988 w/1jzte/afic/3" stainless exh
Old 09-02-2009, 03:43 AM   #5
MADMAX
MADMAX is on a distinguished road
Ok Guys I think I might be able to help with this one.
My 85 supra did the same thing in the 90's.
There is a small and I mean small switch in both doors that fails.
If you remove the inner door panels you can feel inside and down towards the back of the door, there you will find the wire for it, all you have to do is get a new switch if they still make them.
i work with a ex toyota mech and will talk with him to see if any other makes of toyota's takes the same switch.
MADMAX is offline   Reply With Quote
Passenger Door Wont Properly Lock SideWinderGX Car Audio and Alarms 2 03-03-2009 09:08 PM
Gas Tank Door? louie1086 Non-Generation Specific Questions 3 10-20-2008 02:50 AM
alarm problem toyosup MKIII Supra 1 04-03-2008 03:16 PM
Car alarm with a mind of its own suprascoot MKIII Supra 10 03-08-2008 11:09 PM
gas tank door stuck open tonystarks MKIII Supra 1 05-18-2006 09:59 AM
