Old 08-07-2005, 10:32 PM   #1
1stsupraowner
1stsupraowner is on a distinguished road
Im looking for a auto place in town or online to get 2 seals for where the axles come out of the differntial. 85 supra non turbo. Autozone cant get them. I bought 2 from Car Quest and there about a milameter to small or not even. Slides in, where they should be pressed so I have no idea what to do but look for bigger ones but where?
1stsupraowner is offline   Reply With Quote
Old 08-08-2005, 10:07 AM   #2
Poodles
if all else fails, go to the dealer...and hope they don't want too much :unsure:
Old 09-24-2005, 08:51 PM   #3
hangsupra
Smile
there is two type of differntial for the mk2 supra. one is for the LSD n the other is non LSD. look on your vin # under the hook where the axle codes are. there sure be something like this. xxx.xxxx.(xxxx).xxxx. (last # on the ( )axle code) if the last digit in the axle code is a 3 or a 5 then your differential are a LSD. that i know that its a diff. differential tho. double check n buy again. hope this work. correct me if i wrong peoople.
seal packing? dannydavi MKIII Supra 3 12-22-2008 08:34 PM
Replacing rear pinion seal bmc52387 MKIII Supra 1 10-18-2008 11:13 AM
Rear Main Seal mkiiisupra MKIII Supra 3 09-28-2007 02:31 PM
windshield seal theWeezL Non-Generation Specific Questions 0 05-25-2006 06:18 AM
