Old 09-16-2005, 06:43 PM   #1
tonster
tonster is on a distinguished road
Default vacuum advance/retard
how do you test the dual diaphragm vacuum distributor? i replaced all the questionable vacuum lines and any others i could easily get to anf no luck with the idle. so i tried disconnecting them one by one with the car idling to see what it would do and the only one that made a difference was the top line to the unit on the distributor. both did have a vacuum though, but when i disconnected the top line the idle dropped to 650. any ideas? if i need a new one, where could i get one and how much do they cost?
tonster is offline   Reply With Quote
Vacuum hose suprabahamut MKIII Supra 10 01-08-2009 12:52 AM
Vacuum??? fienloco MKIII Supra 4 08-21-2008 04:36 AM
really could use help - vacuum, race on the 26th carl johansson MKIII Supra 2 12-24-2007 11:37 PM
Vacuum tube placement? atsomepoint Non-Generation Specific Questions 13 09-20-2007 02:02 PM
Newbee: Question About Vacuum lines.. Alejo_NIN MKIII Supra 3 01-12-2006 07:18 AM
