Old 01-10-2010, 05:30 AM   #1
Frankie J
Frankie J is on a distinguished road
Exclamation Compression numbers
I got a compression check on my new 84 supra, but I have no idea whether they are in the range that they are supposed to be. What are the right numbers for this car? The motor has around 160,000 miles on it
Frankie J is offline   Reply With Quote
Old 01-12-2010, 12:09 AM   #2
http://www.cygnusx1.net/Supra/Librar...Section=EM&P=6
164 psi
min pressure 128 psi
14 psi difference between cylinders
what are your numbers?
Cylinder Compression Values SupraSleuth MKIII Supra 6 08-17-2009 11:53 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
what are factory compression test numbers? 2JZEFINI-17 MKIII Supra 1 11-05-2006 11:58 PM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
