#1 |
I have a 1984 Supra and I can't figure out why it is hesitating. I've changed the fuel pump and fuel filter, spark plugs and spark plug wires, purged the fuel injection system, taken her on some good runs on the highway, and changed the air filter, and it's still hesitating. Any ideas?
On a different note, the heat doesn't work. I can get it to blow out cold air, and only at one setting, but no heat. If anyone has any ideas, please help, I don't know what else to try. |
#2 |
explain this hesitant problem more please
by it i assume your engine, along with plugs did you look into plug wires and distibuter cap??? also check all your vacume lines for any cracked or torn lines...
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#3 |
Hi thanks for responding. I figured it out. It was a problem with the position of the rotor in the distributor.
