Old 03-12-2010, 02:55 AM   #1
super83
super83's Avatar
super83 is on a distinguished road
Red face know any CAMS?
anyone know a good cam choice to go with on a 5M, looking for a little umph to put into the 5M before i swap it out later, i was thinkin that come better cams would do and sadly not as much is offered for the 5 as everything is for the 7, thanks.
super83 is offline   Reply With Quote
Old 03-13-2010, 03:39 AM   #2
midwestmk2
midwestmk2's Avatar
If you can get ahold of some HKS ones or some GUDE regrinds you should get what you are looking for.. There also have been some guys who have theirs reground to their own spec you will just have to source out a company who will or can do it.. There are some who have shaved the cam towers just to increase the valve lift and gain some power but you will have to reposition the tensioner a little more than stock to make up for the slack in the timing belt..
7mge cams mk3000 MKIII Supra 0 09-12-2007 08:28 PM
n/a cams in a turbo 7m kidthunder650 MKIII Supra 6 04-09-2007 12:48 PM
na cams on a 7mgte noa324 MKIII Supra 0 09-04-2006 12:11 AM
Looking for good adjustable cams SupraSaver87 Non-Generation Specific Questions 3 08-05-2006 08:43 PM
cams supraboy8809 MKIII Supra 2 01-13-2006 08:18 PM
