Old 05-28-2010, 01:04 PM   #1
Default over heating
after installation of new pace setter headers, and exhaust it says ive been over heating. i heat wrapped the headers, and intake and it still said i was over heating... i even checked spewed a bit bit of anti freeze,
ive checked and i have no error codes, and my oil and antifreeze levels were fine, oil pressure and engine preformance seems fine so i do not believe bhg...
any ideas, my temp gauge sometimes tells me max temp... do i just need a better radiator??
oh and the faster i go the cooler it gets...
Old 05-29-2010, 02:05 AM   #2
907mge
907mge's Avatar
That doesn't make much sense since you did wrap them. The pacesetter I just installed has no effect on temp even with the a/c on. All I could think is that it is something in your cooling system or something with the o2 sensor. Mine is currently running without the sensor hooked up.
Old 05-29-2010, 05:12 PM   #3
thats what i think is happening, if you look on my profile pic album you can see the dumb o2 sensor position...
but ever since i did a slight rad flush, it hasnt happened. and yesterday, because i just insured my samurai for 3 months with a new hg, and carb. i juts didnt care so i took my supra, for a 1 hour drive to work. didnt even get close to half way temp...
maby i had a bit of a block in the system... also i was about 2 liters low, possibly wasnt enough water...
either way, a piece of the casting, just a thread for a bolt, broke right off my head.!!! so i probly have a few cracks in other places aswell, and ive been rebuilding another head i own.
Bhg???? Over heating maybe head gasket? Thermo? AlexSchuSupra MKIII Supra 2 03-08-2009 02:12 PM
over heating problems, need help turbo_mk3 MKIII Supra 5 01-08-2009 05:04 AM
Help! Losing water and over heating, but no dripping?!?! Moses76 MKIII Supra 5 04-06-2008 12:32 AM
more over heating issues djalkyd MKIII Supra 12 04-09-2006 09:05 AM
Heating problem Lee MKIII Supra 3 10-04-2005 11:50 AM
