Old 07-08-2010, 01:28 PM   #1
Default injectors
anyone know of any injector upgrades for the 5m.
i have a fuel rail and 6 yellow tip injectors for a 88na(i think) i just dont know how to use other clips
is there anything outther that is a direct replacment, same clips and all ...
need bigger!!!!!
Old 07-09-2010, 01:31 AM   #2
There's no polarity to any of the Supra's injectors, just cut the two wires or the old clip and crimp on the new clip either way.
Are the MKII's top feed? If so 7M injectors will probably fit fine... might need to bore out the ports on the fuel rail if the injector inlets are bigger than the MKII's.
Old 07-09-2010, 01:06 PM   #3
i know they will fit in both my 5mge and the 5ms fuel rail.
i just am confused about how to connect them to the harness
i have been searching google and celicasupra but cant find anything for ground zero...
Old 07-10-2010, 05:09 AM   #4
If you're asking something other than just about swapping the clips I have no idea what it is you're looking for... sorry. The clips are easy, I already covered that...
Old 07-23-2010, 02:27 AM   #5
ive been searching for just replacements that will work with my stock clips.
found this if anyone is interested...
http://www.antikmachine.com/dwld/injectors2.pdf
Old 08-24-2010, 07:13 PM   #6
supkar
supkar is on a distinguished road
I believe the stock 4AG injectors work fine and they are 210 cc instead of stock 5m 195cc
supkar is offline   Reply With Quote
Old 08-24-2010, 10:39 PM   #7
yea i have already decided to go that way.
this is gona take me a while, but doing that with fuel pump and a rrfpr or osme sort of fmu,
not needed but i want a megasquirt
A Few Q's on Turbo Injectors Chambers MKIII Supra 9 11-06-2007 03:26 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
what about these injectors Supraman MKIII Supra 7 01-01-2006 03:08 AM
