Old 09-27-2010, 01:24 PM   #1
Default 1984 5m to 7mgte swap
so i found a 7mgte car that the guy is willing to trade for my 7mge car.
as far as i have researched, to put this into my celica supra, i need to relocate the oil filter, get a tach adapter and engine mounts from 5m, as well as oil pan and somthin else from my 5m.
can anyone confirm this??
http://www.celicasupra.com/forums/sh...7mgte-swap-FAQ
also im not so sure about the wiring??
do i just need the ecu, and then get the tach to work?? does anyone know what the other plugs in the engine harness are?? i know 3 of them are for the ecu but what are the other, and what else should i have to switch over??
any advice is greatly apreciated, and i am in no hurry, i will probly start by dropping the engine and tranny in to see where the shifter lands, and then think from there...
im sure it will be easier to think about this when its in the car and im looking at it.
Old 09-27-2010, 02:33 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
I did this swap 3 yrs ago. The mounts u will need to use is pre 89 and it will drop in. Shifter will end up in the right spot.. as for wiring. There is the c1 plug by the junction block that needs wired.. and the other plugs in the glove box is all the signal wires. some for the gauges and others for the ignition wires (tells it whwn to crank) go to 1jz.com and click on the wiring diagrams andd it will tell u what wires are on the 7m harness plugs and wire colors. Then just get a diagram for your mkii. And match each circuit. The swap isn't that hard but harder then a 1jz in mkiii. Any questions I'd be glad to help.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 09-28-2010, 12:40 AM   #3
i was told my 5m motor mounts would work fine.
and i will check out that site thanks alot!
is what i learned about the filter and tach adapter true??
and if the shifter ends up perfect, that would be best!, because this is the nicest supra i have ever owned (body/ rust/ garage kept, lsd works...) and i would prefer to make as little holes as possible.
although i have already drilled a 4 inch hole for IC piping while i was doing some work for a 5mgte (still my dream to have a 5mgte i like the 2.8 5m, and 2.5 1j for the smaller stroke)
i will start reading about the wiring as soon as i have some time!
THANK YOU for a reply, i am really stoked to get my mk2 rolling again, but i am patient and will do this right.... this is my baby.
Old 09-28-2010, 01:13 AM   #4
Travis89Turbo
Yes I'm sure u will be thorough... and u will use the mounts from the 5m that is in the chassis... but the 5m mounts won't bolt to the 7m block (i tried) but the pre 89 mounts for the 7m block will work perfectly.
stock 2jzge
Old 09-28-2010, 01:42 AM   #5
ill take your word for it.
i might just buy some nice new ones, seeing as i got none.
Old 09-28-2010, 02:26 AM   #6
Travis89Turbo
I apologize I skipped over two of your questions. Yes the filter needs to be relocated.
Yes you also need a tach adapter.
When doin the wiring if u can get ahold of the mkiii chassis plugs and cut the 5mge plugs u could make adapters rather the needing to cut the 7m harness or especially your chassis harness...
Now this may be out of line but if u have read my other threads u kno I'm a jz fanatic... I have owned 3 7mgte and they were good engines but I now have a 1jz and know a ton of locals that have 2jz. I woukd highly recommend u consider a jz engine. A LOT more reliable. And faster mod to mod. Without having to open the engine up for the famous BHG like the 7m a jz can make 600hp with upgraded fuel system and turbo. Not to mention they look so much better. And the sound is oh so heavenly!!! I just say this cuz i wish I would have done a jz rather then a 7m after I was done in my mkii...
stock 2jzge
Old 09-28-2010, 03:30 AM   #7
so i should replace the mk2 chassis plugs with mk3 chassis plugs? so that the mk3 7mgte engine harness will plug right in?
i will be getting an entire 1990 car with the 7mgte.
i am only buying this car to get an engine for my mk2 i really dont car for owning another car right now...
i am willing to rape fuck anything from this 1990 chassis i need to get an engine into my mk2
and trust me, all i want is a 1jz. but the bank wont let me, haha
so im goin 7mgte for the time being, so save your j series recomendations until next year at least. lol.
i am fully aware of the power of the j series, but its only what my budjet will allow
(was a jdm 1jztt 84mk2 for sale near me, i almost sold all 3 of my cars to buy it, only 3k for it, had little km on it)
so im already kicking myself in the groin.
Old 09-28-2010, 03:36 AM   #8
Travis89Turbo
Give me your email address and ill send u a pic of the adapters I made for my 1jz in my mkiii... I do all my posting from my cell phone so I can't upload pics. But after I email it to u feel free to post pic for me so others can see also. id appreciate it.
stock 2jzge
Old 09-29-2010, 02:03 AM   #9
Old 09-29-2010, 02:16 AM   #10
Travis89Turbo
Just to clarify to others that pic is of my 1jzgte to ma70 chassis. Plug on the left came from the 1jz front clip and the one on the right is from my 7mgte engine harness c1. The wires left out are for the alternator and the hydro fan. The 7m into the mkii will have to solder alt. Plugs into the chassis
stock 2jzge
89 7mgte swap Boosted_Sicc MKIII Supra 1 11-02-2009 08:19 PM
7mgte Swap SilverBullet05 MKIII Supra 3 07-17-2008 12:18 AM
1986.5 N/A Supra 7mgte swap Posey MKIII Supra 0 03-16-2006 01:15 AM
