Old 09-09-2005, 10:12 PM   #1
tonster
tonster is on a distinguished road
Default smog troubles
im in california and trying to pass smog with an 82 supra. i had a place do a preliminary test and they said it was running too rich so does anyone have any suggestions about what to look at? the guy there said to check and make sure there were no leaks in the air intake and then maybe the o2 sensor and the air flow meter. i need this car for a lil longer to get through college!
tonster is offline   Reply With Quote
Old 09-21-2005, 11:02 PM   #2
chinhofive0
chinhofive0 is on a distinguished road
Thumbs up
My 84 just failed (the under 25 mph test!!!) and I'm currently waiting for CAPS approval. You pay the first $100 and they'll kick in up to $500 for smog repairs. Same thing happened on my previous check and I got a new EGR & modulator and an 02 sensor from Toyota. I wonder what they'll find this time around.
chinhofive0 is offline   Reply With Quote
Old 09-24-2005, 10:21 PM   #3
hangsupra
iono if you are a mach. or not. if you not exper. for car dont do this. but same on me. on my 85 supra. but i got to work. i live in cali. to. i adjust the afm n my thorttle body. on the afm on the black plastic plate on top of the afm. they glue it. all i do i cut those glue off from the black plastic on top of the afm. if you adjust to the right n i think its lead n the other way is a leak. well i got my to work tho. let me know how you get ur to work.
need help for smog 84supradude MKII Supra 0 02-02-2009 11:05 PM
BVSV interchangability?/ Smog josh_crosson MKIII Supra 3 08-16-2008 01:36 AM
Free $$ to fix failed smog test cars - CALI specific mrnickleye Non-Generation Specific Questions 2 06-19-2008 12:20 AM
map ecu troubles turbotaco MKIII Supra 2 01-03-2006 07:41 PM
1jz-gte smog test aznwaterboy Non-Generation Specific Questions 6 10-24-2005 01:43 PM
