Old 03-15-2007, 09:17 PM   #1
MatCauthon
MatCauthon is on a distinguished road
Default Headlights wont rise
Hi all.
I just bought an 84 Supra, the only problem with the car is that the headlights wont pop up. I can move them up and down manually by twisting the knobs on the motors but they wont come up automatically. The lights turn on fine but they stay down. I just replaced the light retractor relay but that wasnt it. I was told it might be a "blue box" called a "headlight retractor control", but I cant find it. I could really use some help.
Thanks
MatCauthon is offline   Reply With Quote
Old 05-02-2007, 03:19 PM   #2
Stymee14
Stymee14 is on a distinguished road
Default Head Light wont rise
The "Headlight Retractor Control Relay" is located under the dash panel, above the steering column. Hope this helps.
Stymee14 is offline   Reply With Quote
Old 05-02-2007, 07:51 PM   #3
tone loc
tone loc's Avatar
if you need to drive at night and your lights dont work you can put them up manually. pop the hood and right next to the headlights there is a twist knob that you can turn
Old 05-30-2007, 12:50 PM   #4
ssaskiksubucni
ssaskiksubucni is on a distinguished road
if both of you accually read, you see that he said he changed the motor relay AND he knows how to put the lights up manually. Check the motors and check all wire connections. pop up lights are very tempermental and need to be messed with.
ssaskiksubucni is offline   Reply With Quote
Old 05-30-2007, 04:01 PM   #5
Stymee14
Default Head Lights Wont Rise
If you would have paid attention in grade school, you would realize the correct spelling is actually and not accually, I guess that is backwood PA's way of spelling words (lol).
I know there are two relays associated with the headlights in 84 supras. One is the headlight relay and the other is the retract control relay (which is found under the dash, near the steering column).
I suspect if he replaced the retract control relay where I told him he could find it, his response back would have been, "I changed that relay out" instead of him saying to me, "Thanks alot man! I'll check that today".
See if your stare and wiggle test work for the headlights.
Old 05-30-2007, 09:26 PM   #6
ssaskiksubucni
[QUOTE=Stymee14]If you would have paid attention in grade school, you would realize the correct spelling is actually and not accually, I guess that is backwood PA's way of spelling words (lol).
--What your mr. comedian now? good one. now lets here the one that hasn't been used four million and fourty three times. (By the way, the best thing about the backwoods, is no one complains about anything. i want to see you work on your car at 2a.m. with no one complaining)
Old 06-10-2007, 04:00 AM   #7
ogh
ogh's Avatar
ogh is on a distinguished road
check to make sure the ground wire is still mounted under the coil, mine stoped working all the sudden and that was the problem
ogh is offline   Reply With Quote
Old 11-12-2010, 09:34 PM   #8
Saxondog
Saxondog is on a distinguished road
Default 91 Supra headlights
Could you be more specific about the ground wire? Are you saying the ground wire under the coil effects the headlight motors?
I have replaced the relay under the hood,no effect. Really sucks having to leave the headlamps in the up position.
I need some help figuring this out,they just stopped working.
Saxondog
Saxondog is offline   Reply With Quote
Old 11-13-2010, 07:52 PM   #9
cosmos
cosmos is on a distinguished road
I have the same problem with my 82 Mk2. I hope this thread helps.
cosmos is offline   Reply With Quote
Old 11-14-2010, 04:55 PM   #10
going to work on my car this afternoon, ill replace hood and under dash one at a time and see what happens.
ill let you all know in about 7 hours when im done workin on my supras
Headlights not working SilenceboneSupra MKIII Supra 1 01-08-2009 10:08 PM
Headlights going bonkers! RNEMESiS42 MKIII Supra 3 12-17-2007 08:39 PM
headlights for kitcar please help? ripcurl0_0 MKIII Supra 0 10-31-2006 02:41 PM
Projection Stly Headlights? critterCQB MKIII Supra 6 10-17-2006 04:27 PM
