Old 09-14-2005, 07:11 PM   #1
tonster
tonster is on a distinguished road
Default idle adjustment?
how do you adjust the idle on the 5m-ge engine of an 82 supra? it idles around 1200 rpm and i think that might be part of my problem
tonster is offline   Reply With Quote
Old 09-15-2005, 12:12 AM   #2
HPF Jeff
HPF
HPF Jeff's Avatar
HPF Jeff is on a distinguished road
The first think I would look for are vacume leaks around the manifold. A lot of those vacume hoses are going to be old/cracked, so you might just go to your local autoparts store and get 15' of various size vacume hose and replace them all one by one.
The other thing you might look at is the coolant temperature sensor. The sensor might think the engine is always cold and leave the idle at the higher rpm level...
Jeff Gore
(866) 473-5600 x 110
www.horsepowerfreaks.com
HPF Jeff is offline   Reply With Quote
Old 09-24-2005, 10:09 PM   #3
hangsupra
try those thing first. if not working then try to adjust your thorttle body.... it sure work some how.
Idle adjustment for A/C? Staceman MKIII Supra 4 05-19-2007 03:06 AM
Finally, Idle Set! scruffboy Non-Generation Specific Questions 6 01-16-2007 02:39 PM
