Old 06-15-2012, 01:40 AM   #61
mechrider89
Got everything back together today and went to start the car..........it burst into flames!
I would have took pictures if I hadn't been so busy putting it out, have no clue what went wrong never had something like this happen to me before at all!
Old 06-21-2012, 01:36 AM   #62
going to send out the wiper motor for sure this weekend. been hectic...
Old 06-24-2012, 01:33 AM   #63
mechrider89
Old 06-26-2012, 03:39 AM   #64
Mk2guy
Mk2guy's Avatar
Mk2guy is on a distinguished road
It burst into flames. Are you leaking fuel? I have a degree in automechanics so, if you give me some more detailed information. Maybe I can help you figure it out. such as did it back fire. This helps rule things out.
Mk2guy is offline   Reply With Quote
Old 06-27-2012, 12:30 PM   #65
mechrider89
Ya it was a fuel leak, I had a couple injector seals blow out. The fuel problems fixed and my cars up and running but I think I just confirmed my suspicion that I have a cylinder head problem.........piss me off. got to do a leak down and compression test first but I'm sure my head gaskets gone or the heads warped.
Old 06-27-2012, 07:43 PM   #66
Mk2guy
Mk2guy's Avatar
Now, those head gaskets seem to blow every 60k miles. I don't know why. I had to have my block shaved on mine, but that is unusual too.
With great cars comes great responsibility...... or not!
Old 06-27-2012, 08:04 PM   #67
Mk2guy
Mk2guy's Avatar
Also, I was wondering if.... See I bought big bore pistons, the ones from 1985 (toyota racing) and I was wondering if anyone has any experience with them. I am not going to install them for quite a while, but I was wondering how unreliable would a 5mge engine be with them in it? I have no idea, but have you heard anything?
Old 06-27-2012, 10:42 PM   #68
if they are 85's i would assume dome topped. you will notice no differnece in reliability, but a small compression difference.
the 5mge is a great engine. hands down.
Old 06-28-2012, 01:43 AM   #69
mechrider89
CanadianBak'inSupra is the guys to listen to man, I'm still very much new to the supra so I'm not the best guy to ask hahaha.
But higher compression pistons shouldn't cause the engine to be unreliable, might have more HG failures because of more stress on the HG then what its designed to take which could be solved possibly by torquing it tighter.
I went out sliding the supra last night (couldn't help it!) and after coming out of my first drift the engine died out...... never had that happen! My gut feelings saying more and more that my HG has failed. White smoke when its rev'd (weird there's none when idling), sluggish rev and I don't get how but there's what has to be coolant seeping out of the exhaust manifold gasket on to the header, yet I've looked all around the bottom of the head and found no leaks, its definitely coolant seeping out of the exhaust gasket because i'm going through coolant. So I'm thinking its most likely failed in two spots on the exhaust side (cylinder 2 and 4), but what I don't get its why it only smokes when rev'd shouldn't it smoke at idle to?. I've topped it up the coolant started it up and watched to see if it started to bubble and nothing.... so I might have to pull the plugs and borrow the inspection camera from work and take a peek to see if there's coolant in the cylinders.
Old 06-28-2012, 02:37 AM   #70
alum heads on cast iron blocks do weird things.
not 100% sure but at higher rpms the cylinders may be under greater pressure, forcing exhaust gases into your coolant, once it initially happens its going to go the other way and coolant will go into your cylinders.
get a compression check like you planned.
if you do a tear down, give the cylinder head a fine inspection for cracks, what may look like a casting turd/line could be a fatal crack. then go from there...
if it turns out your head is cracked, i do have 3 in my garage... and last i checked lordco can still get rebuilt heads for about 500$
