Old 09-18-2012, 11:42 AM   #111
did you put your cams 180 out?? i have done this once before it happens...
Old 09-18-2012, 12:20 PM   #112
mechrider89
The compression before I pulled the head was
#1- 170 psi
#2- 165 psi
#3- 170 psi
#4- 140 psi
#5- 170 psi
#6- 150 psi
Here's some pics:
intake cam
exhaust cam
dizzy
Crank timing
I pull the timing belt back off and made sure everything was perfect with its timing marks but I noticed I couldn't get the timing belt on then.
Old 09-19-2012, 03:59 AM   #113
mechrider89
Ok well I found my dizzy was 180 degrees out so I flipped that around and turned the key.......VROOM! it started has a little cough and stutter at the start every time but after that she has a steady idle and responds well to throttle. But of course there's bad news I'm hoping my valve aren't hitting my piston on one of the cylinders and its just lifter tick but I'm very worried. I checked the timing another 2 times and its good all around this time tho.......hmmm
Old 09-19-2012, 12:04 PM   #114
its a non interference engine, so even if your cams were 180 out your valves cant hit.
did you clean all your lash adjusters??
Old 09-19-2012, 12:22 PM   #115
mechrider89
nothing more then wiping them off and them bleeding them in oil before install.
Old 09-19-2012, 11:39 PM   #116
that should be fine, but more than worth the while to clean them with varsal or brake cleaner first, let dry, then prime with light weight oil
Old 09-20-2012, 04:18 AM   #117
mechrider89
I didn't know it was safe to clean them with break clean hhmmm I may get another shot at cleaning them tho, as my com tower gaskets might be leaking already...... i didn't know they were different so I just grabbed one and installed the cam tower. After I got both on a realized I fucked up
Hey and bak'in wondering if you have a wiper control unit laying around?
Old 09-20-2012, 12:41 PM   #118
i can take a look around. do you have a picture?
either way in a few months im getting a free celica supra.
Old 09-22-2012, 06:04 PM   #119
mechrider89
free?? wow your hooked up good, are you going to part it out or keep it?
Here's a pic of the wiper control module. should be brown like this:
Its located passenger side kick panel by the door and hidden behind another yellow control module.
Old 09-23-2012, 02:17 PM   #120
ill take a look around, but i am getting a parts supra, so if you have not gotten one by then, i will have one for you.
