Old 03-22-2011, 03:25 PM   #1
Default Ignition problem
car:
84 celica supra
Engine:
5mge
mods:
auto to 5speed swap
ok so recantly my car does not want to fire at all...
put in new plugs, cables and the top piece of the ignition coil, new battery cap and rotor. i even tested 2 dist. i had and nothing.
randomly it starts to work i dont get it...and then randomly it doesnt start...
my haynes manual says to check battery cables (done) dist.(done) cable and plugs(done) cap and rotor(done) ignition timing wrong (already set to 10 degrees @ 650rpm as of 4 days ago)
only other things it says to check is water in fuel and clogged injectors(my injectors are brand new i paid lots of money for them) and my car is garage kept so obviously water is out of the question....
any ideas?????
88 1jz swap ignition problem. HELP plz! bdavis89 MKIII Supra 1 02-10-2011 03:23 AM
ignition problem??? ratiugslinky MKIII Supra 30 05-01-2008 06:29 AM
Ignition Problem Burning Pyro MKIII Supra 9 04-24-2008 02:31 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
