Old 10-12-2011, 09:21 PM   #1
jgentleman
jgentleman is on a distinguished road
Default Coil connector wiring
I received a dis-assembled 1988 NA 7MGE and I have a wiring issue. There is a green 4 wire connector going to the coil and the wires are pulled out. The attachment shows it pretty well. Which wire goes where?
jgentleman is offline   Reply With Quote
Old 10-16-2011, 07:44 PM   #2
mechrider89
If I had a mk3 I'd tell you but I don't sadly. :-(
Some one in the mk3 forum should be able to help you out.
Tags
coil, connector, wiring
No ignition coil spark. Plz help!! MrMK3-707 MKIII Supra 6 12-29-2010 09:20 PM
Coil pack issues!!!! Supra_Sicc MKIII Supra 9 11-05-2009 05:07 AM
No Spark From Coil SilenceboneSupra MKIII Supra 10 10-17-2007 03:10 PM
How to install blaster ss coil? merryprankster Non-Generation Specific Questions 0 07-17-2007 12:51 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
