Old 03-02-2012, 01:05 AM   #1
jhampton46
jhampton46 is on a distinguished road
Exclamation I need help!!!
I have an 84 supra and have a couple of problems. First the low beam headlights quit working. High beams work great, but no Lo-beams.
And the other problem. The clutch will not stay primed. I've replaced the slave cyclinder and the resivour twice each with no result. I had a guy at a transmission shop tell me it could be the slave cyclinder over extending due to a worn clutch disc. So i replaced that too. No help there either. I thought line problems but the system doesn't lose any fluid.
Amy suggestions?
jhampton46 is offline   Reply With Quote
Old 03-02-2012, 01:10 PM   #2
how is the wear on your clutch pressure plates??
Old 03-02-2012, 01:13 PM   #3
jhampton46
It's brand new as well.
Old 03-02-2012, 09:08 PM   #4
Bent fork? Is there supposed to be a bushing on the end of the slave's linkage?
As for the headlights, does anyone have a decent wiring diagram?
Old 03-03-2012, 12:11 AM   #5
ive got the haynes manual wiring diagrams. just folow your wiring back and check your fuses. is your steering column switches working fine??
as for the fork, there is no bushings, just a ball the fork goes on, and gets grease. the slave just pushes a divot in the fork.
i cant find any pictures of the fork best one...
http://www.cygnusx1.net/Supra/Librar....aspx?S=CL&P=7
Old 03-05-2012, 05:12 AM   #6
jhampton46
Thanks for all the suggestions. I live in southern Indiana just about 5 miles from where all the tornados hit so things have been crazy.
The situatuion with the lights, ive got a chiltons manual so I think im gunna look into it and start following wires.
With the clutch problem. Still no answer there. I did talk to my brother about it and he said there's some kind of check valve between the metal and braided lines going from the master cylinder and the slave cylinder. Any ideas there?
Tags
clutch, headlights, transmission
