Old 07-11-2012, 04:26 PM   #1
jadeb333
jadeb333 is on a distinguished road
Default CHECK ENGINE (temp gauge/RPM) flutters when hitting bumps (bogging)
5mgTe 83
obviously, my first idea was something was knocked loose while accidentally jumping my car into a drift.
the very day I did this, and a few days later I noticed no problems. but when finding myself hitting bumps in the road during the week, i figured I probably have knocked a sensor or something loose. the temp gauge would drop completely for a second, the rpm gauge would also drop about a 1000 rpm, and the car seemed like it tried to die, but didn't stall while in gear. the check engine light will come on after hitting bumps but only stays on for about 15 seconds. It's also back firing and shooting fire all over the place now which it didn't do while regularly decelerating.
I've checked the distributor and ignition coil and all the spark plugs, everything seemed connected and good. my ecu is bolted to where the glove box used to be, and i tugged on the connectors and some wiring near it at idle. it wasn't consistent, BUT i did notice that the idle did drop for a second once or twice while doing so. but when tugging the same ones a second time it didn't respond. can anyone guide me to some possibilities of what it may be?
thank you for anyone with information or ideas of a sensor or something causing this
jadeb333 is offline   Reply With Quote
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
check engine light Clorox9 Non-Generation Specific Questions 1 05-08-2009 06:57 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
