Old 09-16-2012, 05:54 PM   #1
johnmfoschi
johnmfoschi is on a distinguished road
Default Clutch slave cylinder leak
my clutch reservoir when empty and I filled it but did not bleed it. Since filling the reservoir I have smeller burnt brake fluid so I have searched and found fluid in the rubber boot between the slave cylinder and the transmision. Any idea as to what I should do? Could this be caused by not bleeding the air out of the line? Is this a sign that the slave cylinder is bad and should be replaced?
johnmfoschi is offline   Reply With Quote
Old 09-29-2012, 12:51 AM   #2
Well, it's a little late but I didn't see this as it was posted in the wrong forum. If you still need help with this let me know what year Supra you have and I'll move this to the correct forum. Posting which engine you have may help too. Be concise when posting new threads, it saves a lot of time.
Old 09-29-2012, 01:53 PM   #3
johnmfoschi
Default clutch problems
My leaking clutch slave cylinder is on my 1982 Toyota Supra. It is a 5 speed manual transmission and the engine is the 5M-GE.
Could this leak ruin my clutch or harm the transmission? Will replacing the cylinder fix all?
Old 10-12-2012, 12:17 AM   #4
I'll move this thread to the MKII section where it belongs.
No, a leaking slave isn't going to ruin your transmission but excessive wear on the clutch and damage to the clutch plate and flywheel are possible. The slave cylinder is a very simple device, I'd rebuild it but they're cheap so just swapping in a new one shouldn't break the bank either. If the slave really is where the leak is then yes, replacing it should prevent and *new* damage.... It won't undo any damage which may have already been done though.
Old 10-13-2012, 05:58 PM   #5
when you buy a new slave cylinder or rebuild one. you Will have to bleed all the air out. its worth looking at your master cylinder too. after all your car is 30 years old.
how to bleed clutch system:
http://www.cygnusx1.net/Supra/Librar...Section=CL&P=3
Tags
clutch leak
Clutch master cylinder leaking after 8 months? Awyman18 MKIII Supra 4 05-27-2016 12:26 AM
Need Help with Replacing Clutch Master Cylinder xxx609 MKIII Supra 7 02-01-2012 01:36 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
clutch slave cylinder AbsoluteSpeed MKIII Supra 2 09-20-2007 05:20 AM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
