Old 05-05-2013, 02:29 PM   #11
Originally Posted by 86supra View Post
alright i got codes 11 14 and 52 so iam trying to find the relay and check that but it starts in the moring fine but in the afternoon it wont start at all no spark i dont get
Agreed those are all codes that MUST get fixed you should be able to run with a code 52 it just may not run good. Aswell is cleaning all your ground points, it's a good idea to check all your fuses and any relays relating to your ecu.
Old 05-06-2013, 12:09 AM   #12
With regard to the code 52: The heavy increase in fuel and the retardation of ignition advance may cause a significant problem actually. It can be enough to cause problems starting the car by itself but when compacted with the other problems well, I'm not surprised the car isn't even running half the time.
Old 05-08-2013, 05:24 PM   #13
86supra
86supra is on a distinguished road
thanks iam goina start cheakin wires had prbs with some wires before fun fun lol thanks you all for the help
86supra is offline   Reply With Quote
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Roll start but no key start. Need help Mrow MKIV Supra 1 09-11-2011 06:11 PM
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
