Old 09-01-2015, 04:30 AM   #1
mk2life
mk2life is on a distinguished road
Default 85 Mk2 transmission swap
Hello, i currently have an 85 mk2 in auto, as obvious; it's pretty dull and im looking to swap in a 5 speed tranny, only i'd really love to know every single component i would need (say i get it from a pick n pull) id want to be sure i have everything to make the swap a success, thank you!
mk2life is offline   Reply With Quote
Old 09-24-2015, 12:00 AM   #2
Mike 65
Mike 65 is on a distinguished road
I am not so sure that you are going to find too many salvage yards that still have cars from the 80's. But, you will need
the trans and clutch assembly
shifter and linkage
the pedal and all associated hardware
The trans mount might be different so grab it just in case
You'll also need a wiring diagram to deal with the trans computer that is currently interlaced with the ECU and speed control computer
The starter wire also goes through the tranny and that will have to be corrected.
Mike 65 is offline   Reply With Quote
Transmission Swap jz36 MKIII Supra 0 05-28-2010 10:06 PM
Transmission swap Jason Van Dyk MKII Supra 2 05-20-2009 06:13 PM
Transmission swap price? deadcell9156 MKIII Supra 1 04-29-2009 05:11 AM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Transmission swap fulljapan MKIII Supra 1 07-11-2007 07:09 AM
