Old 12-10-2017, 11:55 PM   #1
Not the end of the world infact a fairly easy fix if you have any experience with timing belts and pulling out old seals.
I would recommend purchasing a whole timing belt kit that comes with front seal and camshaft seals.
If you don't have the money to purchase the entire kit simply buy the front main seal it requires if memory serves to have the timing belt removed and the crank shaft snout exposed, all can be done with the engine inside the car and radiator and ac cooler removed.
personally I put thread locker on my harmonic balancer too. If you have any question about the procedure I am happy to help
Old 01-23-2018, 08:43 AM   #2
tmothy3
If you are not mechanicaaly inclined, just go to a reputable shop to have the seals replaced.
Re-torque head gasket from 56 ft./lb. to 75 ft./lb. (Good idea or bad idea) Randy0223 MKIII Supra 4 04-23-2011 09:50 PM
Changing head gasket questions??? linuxgurupodboy MKIII Supra 10 02-22-2008 10:51 PM
gasket help hangsupra MKIII Supra 14 01-28-2007 05:35 PM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
