Old 10-23-2005, 08:20 PM   #1
kranke9
kranke9 is on a distinguished road
Default Supra NEWBIE!
HI guys, just picked up an '85 w/ the 6mge engine. I had a couple overheating probs on the way home, but i think i fixed that by replacing the water in the radiator with coolant. My question is; is this common with the 6m? My other question is will exhaust headers for a 5m work on the 6m? I also have been looking for a short throw shifter, the original just flops around WAY to much for me. I am still searching through the faqs and threads, but if you can give me a few key search words to help me out that would be great. Thanks alot folks.
P.S.-Happy to be a supra owner.
kranke9 is offline   Reply With Quote
Old 10-24-2005, 08:23 AM   #2
midwestmk2
midwestmk2's Avatar
Smile
Welcome to the Mk2 headache..No just joking..Pretty much everything from the 5MGE and 6MGE are identicle except the crank and timing gear..If the car hasnt been tened to on a regular basis you might start your prevenitive maint. ..Like thermostat,fan clutch,flush and burp cooling system..If it continues to over heat try the IAC valve,Then if it continues you might have a cracked head or leaking head gasket..Keep us posted and good luck..
Old 10-28-2005, 03:19 PM   #3
hangsupra
pretty much he said it all... but if you looking for shifter... the mk3 shifter will fit on your mk2 supra. thats what i were using for my mk2.
Old 10-29-2005, 05:52 PM   #4
kranke9
Thumbs up
thanks guys, just got the valve covers resealed, and replaced the o-rings behind the cams. my next question is if there is a supra pro in washington state? That and has anyone found a short throw shifter for less than $300? I am in the army, and taking college classes, so i only get weekends with my baby. Thanks again guys
Old 11-20-2005, 02:45 AM   #5
hangsupra
i not so sure about the short shifter but i were using a short shifter from the mk3 on my mk2 tho..... thats what i were using....
Old 12-05-2005, 09:23 PM   #6
scorpmatt
scorpmatt is on a distinguished road
A buddy of mine had a mk3 supra (87) and he took it to the greg's jap auto in kent/auburn. they took care of his care really well. He sold his mk3 recently for a mr2 turbo, he took that to the greg's in puyallup and they didn't clamp down the boost hose correctly and it fell off while he was driving down the highway, taking some of the years off of the turbo, as it spooled all the way up. So I guess it just really depends on your area and the mechanics that are working at the shop. but, I wouldn't take anything to the gregs in puyallup, had an 82 accord and they didn't fix the timing nor could they figure out that the transmission was shot.
scorpmatt is offline   Reply With Quote
Supra Newbie Questions Grandavi Non-Generation Specific Questions 9 09-02-2008 07:29 AM
Supra newbie questions. 72charger Non-Generation Specific Questions 4 07-30-2006 01:07 PM
Supra Newbie sloweredk300e Non-Generation Specific Questions 2 11-25-2005 04:26 PM
newbie please help supra TT jason17 MKIV Supra 0 08-31-2005 04:51 AM
