Old 01-17-2005, 06:28 AM   #1
Dave
Guest
Posts: n/a
Hey,
I just got an 82 Supra Celica 2.8 6cyl. Its the fully loaded luxury version and I've got a few questions.
First off, both my AC and heater arent working. No air is coming out what so ever. Heater wise, what could it be? Anything from a fuse to a new blower motor to a new heater core? And as for the AC. How do i check that out and what am I looking at for costs? Also my FM radio doesnt work. Now I dont seem to have an antena and Im not sure where it goes. Does this model have an electric antena or is there an actually one that should be attached on the cars surface? Finally, there are 2 switches on the consol beside the shifter. The first one (farthest away from the dash) is for the Door Locks. As for the second one, im not totally sure what its for. Does anyone know???
Thanks
Old 01-18-2005, 11:28 AM   #2
Brendan F
Brendan F is on a distinguished road
The other switch is for the fog lights (the 'headlights' that don't pop up). They will only activate when that switch is on AND you have high beam on.
I think this is right - corrections are welcome. (i'm a noob too)
Brendan F is offline   Reply With Quote
Old 01-22-2005, 09:49 PM   #3
drew
Guest
Posts: n/a
Concerning your heater blower, a/c difficulty. I had an '85 celica when mine went. I have an '84 supra now and i think the heating system is near identical. On the celica it turned out to be a breaker located behind a plastic kick panel on the passengers side foot area in front of the door, under the dash. it was a two prong little breaker with a metel cap with a hole in the middle. I was told to simply reset the breaker by sticking a pin in the hole and pressing on a switch inside. This didn't work and toyota wanted $80 for a new one so i went to the wreckers and pulled one off another car for fifty cents and it workrd like a charm. The heater blower motor can be a little tricky to replace,try taking out the passenger side of the lower dash (glove box and below) for better access. You should't need to remove too much else but it will take a little wrestling to get it out.
Old 03-19-2005, 06:09 AM   #4
hangsupra
Originally posted by Dave@Jan 17 2005, 06:28 AM
Hey,
Thanks
well...my i dont have the antena...but it attach to the body frame tho...n it give me a very good connection...well....if there is no heater then when you turn your heater on...is it making noise like the blower motor is running on but no warm air coming out or what is it...if the motor is runing or making noise n there is no warm air coming out than....the blower is not good than....so hope that work....
Old 04-03-2005, 07:38 AM   #5
G-string
G-string's Avatar
G-string is on a distinguished road
your heater problems it coudl eb as easy at the brushes for the fans are old and worn they would be the simplest to replace and probly cheapest lol :blink:
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
One more time, my air removal method. Monkey Non-Generation Specific Questions 2 04-20-2007 02:09 AM
0-60 time f00g00 MKIII Supra 16 08-09-2005 05:53 PM
Porsche 951 owner seeks Supra No Ruf MKIV Supra 3 07-31-2005 06:04 AM
