Old 12-12-2005, 12:07 AM   #1
hangsupra
Default turbo ecu for the mk2
i got my 5mge with the mk3 turbo setup.... i change everything... but i keep hearing people from right to left saying that... i need to upgrade my ecu or get a turbo ecu.... so in that way it will be able to run the turbo right n boosting correct... is that true.... do i really need to get myself a turbo ecu for my mk2 turbo since i running turbo.... if so is there any where i can find myself the turbo ecu for my mk2 turbo... cause i dont know nothing bout the ecu turbo for the mk2 supra. anything will help n appr. thanx n hope to hear from you guy. n this question is from myself... i need it to know... so please help out to. thanx.
Old 12-13-2005, 04:07 AM   #2
SKILMATIC
SKILMATIC is on a distinguished road
You know Ive heard the same thing however, I dont know for sure. I guess the only way to find out is try it ourselves.
SKILMATIC is offline   Reply With Quote
Old 12-13-2005, 05:12 AM   #3
hangsupra
well i keep hear from left to right... upgrade your ecu... or reprogramming your ecu. to run your turbo right... but i dont know who would do it tho. any sugg. i live in 209 cali. let me know if there anyshop where i can reprogram my ecu to run my turbo. or is there any shop/store who selling those ecu turbo for the mk2. let me know. n also how much do it cost?
Old 12-13-2005, 05:22 AM   #4
SKILMATIC
Where in cali? I live in the 619 area which is in san diego. I do know some very baffluent tuners that can help but they will cost you. They can flash your stock pcm. Price can range anywhere from 150-700bucks. Depending on the amount fo work and what you want done.
Old 12-13-2005, 08:22 PM   #5
midwestmk2
midwestmk2's Avatar
Find a HKS fcon unit or another tubo timer..Possibly a fuel controler also..You can use 7MGTE injectors but you will have to cut out the old plugs in the harness and put some in from a MK3 with a 7MGTE..
Old 12-13-2005, 10:12 PM   #6
SKILMATIC
Well we arent talking about turbo timers and boost controllers we are talking about better enginem management in the realm of our stock pcm. Besides a 7mg will not work for the 5mg. And what plugs are you talking about? I may have misunderstood you here if I have done so I apologize.
Old 12-14-2005, 03:41 AM   #7
midwestmk2
midwestmk2's Avatar
The injectors from the 7M should drop right in with little or no mods and i was refering to the plugs in the harness for the injectors..They changed the plug style when they put the 7m in the MK3.. On ECU mods I dont know of anyone off hand that does that sort of thing..Most I have seen with turbo 5m's usually dont do any mods like that..
Old 12-14-2005, 03:47 AM   #8
SKILMATIC
O ok thats what you meant. I was a little confused there. Sowy
Old 12-14-2005, 04:11 AM   #9
midwestmk2
midwestmk2's Avatar
Talking
Kinda scary..This is the most action that this forum has gotten in a while..Im glad to see y'all..
Old 12-14-2005, 05:05 AM   #10
SKILMATIC
What you mean?
