Old 12-22-2005, 09:13 AM   #1
supramadness
supramadness is on a distinguished road
Default is there differnt models
are there different models in the mk2 as i am looking at buying one
hey i own a ra 65 celica its all i could aford (damm parents ) o well looks like i have to save for a mark 3
supramadness is offline   Reply With Quote
Old 12-23-2005, 03:19 AM   #2
midwestmk2
midwestmk2's Avatar
I take it you gav up on the MKIV idea.... Good idea you can swap the drivtrain out of a MKIV into a MKII and be alot lighter also..Less wheight means more speed..Yes there are diferent models..There are slight changes in the body panels per years also..The 82 to 83 models had a single front facing turn singnal and a one peice spoiler that went over the top of the hatch.. The 84 to 86 had a signal that wrapped around the front corner of the fender and had a 2 peice spoiler trhat had a small portion at the top and continued down the hatch and then formed a duck tail type of lip...There were also diferent model options..For instance there is the L-Type and there is the P-Type..Mine is a P-Type which is noted by the spoiler and the fender flares..All of the L-Types were not available with the fender flares and some if not any came with a spoiler of any kind..L-Types also did not get headlight washers..The P-Types are very hard to find with a leather interior but almost all L-Types came standard..If you would like to learn everything then go to the celicasupra.com forums and look under the FAQ section and use the search and all of your questions will be answered there..
Old 12-23-2005, 05:55 AM   #3
supramadness
cool thanks for that that is really helpful
Models Go Here. Car Models, That Is--Post 'em up! Warning: Pic Intensive TONY! Off Topic Forum 26 11-28-2008 09:46 PM
I got lost trying to compare all the MP3 models so.... dennis7 Car Audio and Alarms 2 07-19-2007 03:29 AM
