Old 01-29-2006, 12:30 AM   #1
spastek
spastek is on a distinguished road
Default car wont start
so heres the deal i swaped my blown 5mge in my 85 supra for a running 5mge out of an 84 cressida the only thing different on the motor was the lack of a knock sensor... and now ive got everthing back together and i was trying to start the car and all it does is pop and bang doesnt want to start ive checked the timing a couple of times all the connections everything i can think of anyone got any ideas?
spastek is offline   Reply With Quote
Old 01-29-2006, 01:28 AM   #2
spastek
I kept the cressida's intake could the injectors be wrong for my supras computer like a diff voltage or ohm rating?
Old 01-29-2006, 05:51 AM   #3
midwestmk2
midwestmk2's Avatar
JUst did the same swap..Try setting the crank at TDC then pulling off the timing belt and turn the cams to there TDC position(positioning the groove on the cam sprockets with the grooves on the top of the back timing cover)..That means the locating pins are in the middle hole and on the bottom side of the cams..Then pull the distributor and line it up with the #5 cylinder and then slide it back in and it should be right at the #1 cylinder..Then try and fire her up and let me know..
Old 01-30-2006, 07:49 AM   #4
spastek
well i changed the intakes and injectors and re did the timming and she puuuurs thanks for the help...
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
