Old 01-31-2006, 10:45 PM   #1
gpgtp_22
gpgtp_22 is on a distinguished road
Default jdm or usdm
Is it harder to swap the jdm engine than the usdm engine or are they about the same in dificulty. Does either engine make more power or is there any differneces between the two. If i got a jdm engine would i need a jdm ecu.
gpgtp_22 is offline   Reply With Quote
Old 02-01-2006, 06:29 AM   #2
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
They are the exact same just slight diferences in power..The US spec 5MGE is 145hp and the JDM is 170hp..Mostly because of the lower emissions over seas..After you put on your EGR and other emissions stuff it will equal out..The ECU's are the same also..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
is the JDM Map sensor the same as the USDM? zze86 Non-Generation Specific Questions 1 04-03-2006 12:17 PM
