ive got an oil leak on my 85 supra from somewhere under the header i checked the oil filter and the oil pressure sender and there not leaking could it be the head gaskit?
Does your '85 have a 2JZ motor in it?
Because you are in the MKIV section. Just wondering if I should move this thread to the MKII Section, or if there is something I am missing... |
oops clicked the wrong forum yes please move it to the mkII section
Sure it could be the head gasket allowing some oil leakage. You should probably clean the engine, and that will make it easier to see exactly where the engine is leaking the oil from.
where is the leak located at... is it close to the front of the power steering or is it in the back of the egr... i mean where did you see the leaking oil's at
Blown Head Gasket Snake Oil | unkymurch | Non-Generation Specific Questions | 21 | 08-06-2010 02:11 AM |
1989 Supra blown head gasket | rayk5799 | Non-Generation Specific Questions | 6 | 05-18-2009 10:51 AM |
Head Gasket replacement questions. | DavidLeClair584 | MKIII Supra | 1 | 06-09-2007 09:17 PM |
Buying a 87, head gasket questions | Gengus | MKIII Supra | 1 | 04-14-2007 07:15 PM |
Head Gasket Part II | Bullz_EyE | MKIII Supra | 2 | 01-26-2006 06:30 PM |
