Old 02-02-2006, 07:06 PM   #1
no 1 lampy
no 1 lampy is on a distinguished road
Default fuel type
hi there guys . am a newbie to this forum so please excuse me if ths question has come up before.
am now on my 3rd mkii
my question is what type of fuel can i use (unleaded or super unleaded) and do i need to do any mods to run on unleaded.
the last 2 mkiis i owned, i only ever ran on 4 star or lrp. i have now recently bought an almost perfect 1986. however leaded is not available in the uk any more. can i run her on unleaded and do i need to do any timing changes. also am i better off with standard unleaded or should be using the higher octane super unleaded.
cheers
mark
no 1 lampy is offline   Reply With Quote
Old 02-11-2006, 02:08 PM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
I would follow what the manufacturer recommends.
There must be a sticker somewhere on the car, check the glove box.
I would also think that the manual would tell you what you should feed it too.
If I were to guess, I would say that you could use the regular unleaded.
If you hear pinging, go to a higher octane gas.
If you have an '86, then your compression ratio is 9.2:1
That does not sound so high to me.
High compression ratio engines and forced induction engines (supercharged/turbocharged) will need higher octane fuel so they don't ping.
Unless you have a lot of carbon build up (which would increase your actual compression ratio), I would bet that the regular is good enough for you.
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Old 02-14-2006, 04:33 PM   #3
no 1 lampy
hi there thanks for that.
have now spoken to toyota uk
they said about the same
the car was originally designes to run on leaded.
i can run it on standard unleaded by retarding the ignition timing by 2-3 degrees
mark
Old 02-14-2006, 10:48 PM   #4
TONY!
TONY!'s Avatar
Glad I could help
Sometimes I forget that I had an MKII also. heheh
Now that I think of it, I just used regular unleaded when I had it.
I should have mentioned that.
I will post my MKII in my own thread later for you MKII'ers and ask you guys what you think of it....but that is another topic.
Old 02-28-2006, 06:37 AM   #5
hangsupra
try to use the standard unleaded fuel... if dont have the standard/regular unleaded one then try to use the higher octane one and see if it makes any differece....
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
