Old 02-22-2006, 06:11 AM   #1
TargaMKII
TargaMKII is on a distinguished road
Unhappy overcharging battery/electrical system
i have an 1985 supra that likes to charge at about 17 or 18 volts....this continues when i accelerate...but when i press on the brake...use the windows...or shift it goes back to normal...it also charges normal when im at idle...maybe my voltometer is acting up?..but i dont want to take chances..anyone had this problems...and maybe have some possible solutions or maybe things i should check?
TargaMKII is offline   Reply With Quote
Old 02-22-2006, 10:08 AM   #2
get your alternator checked.... i believe there is an item called a voltage regulator inside it which has decided to take a dive on you
well try that first anyhow
Old 02-23-2006, 01:29 AM   #3
Freezenpop
Freezenpop is on a distinguished road
funny, my 83 was doing the exact opposite. It would sit at normal without using electronics, but when i used the power windows or pressed the break or stuck the fog lights on or whatever, it would get down to about 10 or 11 from 13 or so. I just took apart my alternator and replaced the voltage regulator about 2 weeks ago (which seemd to have worked), didn't have it tested though I probably should have. I did wierd stuff when i accelerated into high rpms too but i forgot.
Freezenpop is offline   Reply With Quote
Old 02-27-2006, 02:00 AM   #4
TargaMKII
ive replaced the alternator 4 times...and nothing still with the same result..so its not that..i dont know maybe any other solutions?
Old 02-27-2006, 07:15 AM   #5
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
Buy an external voltage regulator and mount it on the fender by the alt and see if that helps..If not then i can just say let a dealer run a diagnostic on the electrical system..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
Old 02-28-2006, 12:04 AM   #6
hangsupra
it use to happen on my other 85 mk2 supra... and i check on the fuse on the fuse box... and it runs a bigger fuse so when you acceleration then the battery went up or goes up... and replace by the stock fuse then it solve the problem.... so try to check on the fuse... and see that helps you.
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Exhaust System SideWinderGX MKIII Supra 8 02-28-2007 08:01 AM
Cold Air system? Black'88 Non-Generation Specific Questions 10 04-22-2006 02:40 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
