Old 03-03-2006, 04:54 AM   #1
gpgtp_22
gpgtp_22 is on a distinguished road
Default which exhaust?
Im doing the 7mgte swap and i was wondering if exhaust for that engine will work with the mk2 supra or if they are different. Will I need to get a custom exhaust made or will exhaust systems from either car work. Also do mk3 bodykits work with the mk2 ive heard they do but is that with modifications. Does anybody know of good and reliable places that i could get a jdm 7mgte from because my car is just waitin on an engine.
gpgtp_22 is offline   Reply With Quote
Old 03-03-2006, 04:59 AM   #2
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
Check out www.rabidchimp.com They will have everything you are looking for.
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
Old 03-04-2006, 09:34 PM   #3
hangsupra
about the mk3 down pipe from converter to the exhaust... i not sure if it will have the same bent... but yeah the down pipe from the 7mgte sure fit on the mk2... but down on the bottom of the car the pipe is hanging low to the ground tho... my mk2 is 5mge turbo and i were using 7mgte turbo part but not the stock turbo downpipe... i upgrade to a megan turbo down pipe and its hanging too low on the ground.... i cant even roll a soda can under neath my car... it got stock on the megan turbo down pipe tho... well...anyway... the stock turbo down pipe will fit.. but i not sure about the straigh pipe from the converter to the exhaust will have the bent or curl tho... cause i didnt use the mk3 i upgrade my exhaust down pipe to a 3" and the muffler is a 6". and its Raven... Raven is the same setup as the flow master... i like raven more then flow master.... sounds smoother and louder tho... hehe...
well anyway... about the mk3 bodykit on the mk2... i not sure about that if it will fit tho... but however the mk2 does have a add on or clip on kit tho... there is two type kit from the USA that have for the mk2.... but if you get it from Japan... there is alot... but it runs you lots of $$$.... but if you get the stock or the mk2 bodykit from USA then it sure cost nomore then $1,000 but if you get of USA and getting from Japan... it run you about $1,350-$3,500... and it depend on what kind of kit you getting.... if you want picture of my mk2 car then email me and i show you how the mk2 bodykit looks like alright. or go to my site from my profile.... it sure have a link to my mk2 page...
Old 03-05-2006, 06:21 PM   #4
eternal genome
eternal genome is on a distinguished road
Default body kit
i saw an awesome body kit made my extreme dimensions on this web site, andysautosport.com, it says that it will fit a 86-92 supra but i really dont know if it will fit on an older supra cause ive never seen any pics of the kit on any older supras and the pic it provides is on like an 90-92 model. i really like it and its only like 750$. just putting that out there
eternal genome is offline   Reply With Quote
Old 03-05-2006, 06:36 PM   #5
kwnate
I wouldn't expect a mk3 body kit to fit on a mk2 without serious modifying. The body's are totally different especially in the front. Personally I'd buy one designed for my specific car, but if someone has the skills do it!! I'm curious to see how it would look.
Nate
Old 03-05-2006, 06:45 PM   #6
hangsupra
i know that the mk3 and mk2 is totally diff. body style... but however you can modify the mk3 bodykit to the mk2... BUT NEED MODIFICATION.....
my uncle have a mk2 with the '91 mk3 front conversion.... and also the rear taillight/bumper with the mk3 conversion.... and it looks nice tho.... its white with one red/yellow strgh. on the side.... like that one white mk2 supra i saw it on the net here... but cantfind nomore.... cause i just cruse around n saw once thats all... well hope u find something for your car....
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Exhaust Cat Fitting Bill UK MKIII Supra 4 06-15-2008 11:32 AM
Dual exhaust, anyone? lifesnotfair MKIII Supra 13 12-22-2005 10:41 PM
