Old 03-08-2006, 10:26 AM   #1
SAM
SAM is on a distinguished road
Default dash light
hey, i have an 86 n/a 3.0i supra 5spd, evry now n then when im thrashing it a light comes on the dash. its the little amber light right of the door warning light on the dash and has a couple lines behind the car... can any1 tell me what it mean?????? cheers
SAM is offline   Reply With Quote
Old 04-06-2006, 05:32 AM   #2
Freezenpop
Freezenpop is on a distinguished road
is it the red dot that says your not getting battery electrical feed from the alternator?, because that was happening to me int he same situations in my 83
Freezenpop is offline   Reply With Quote
Old 04-06-2006, 08:44 AM   #3
midwestmk2
midwestmk2's Avatar
Either your alternator is going out or you have a bad cable..Could possibly be a ground cable..
Old 04-06-2006, 09:17 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
can you see it in this pic?
Pics of my build.
Do a diagnostic first!
Old 04-08-2006, 07:00 PM   #5
hangsupra
i sure it was something gonna do with the battery. either your alternater or bad battery... or not grounding right...
Old 04-09-2006, 03:50 AM   #6
the_fallen
the_fallen is on a distinguished road
if it's your handbrake light, then check your brake pads. if they are alright, then add brake fluid, if not, replace brake pads and should stop. had that on my jza70 hammering into a 35k hairpin at 120k, handbrake light comes on, passenger "whats that light mean??" "oh the brake pads just let go..." *passenger screams*
the_fallen is offline   Reply With Quote
codes - no light on dash ?? eggybread MKIII Supra 0 12-07-2008 10:33 PM
orange/yellow light on far left of dash (aka: The Birdcage, Carousel, Old Radiator) suprra_girl MKIII FAQ 5 09-20-2007 07:32 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
