hey, i have an 86 n/a 3.0i supra 5spd, evry now n then when im thrashing it a light comes on the dash. its the little amber light right of the door warning light on the dash and has a couple lines behind the car... can any1 tell me what it mean?????? cheers
is it the red dot that says your not getting battery electrical feed from the alternator?, because that was happening to me int he same situations in my 83
Either your alternator is going out or you have a bad cable..Could possibly be a ground cable..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!! http://www.cardomain.com/ride/858848/2 |
can you see it in this pic?
i sure it was something gonna do with the battery. either your alternater or bad battery... or not grounding right...
#6 |
if it's your handbrake light, then check your brake pads. if they are alright, then add brake fluid, if not, replace brake pads and should stop. had that on my jza70 hammering into a 35k hairpin at 120k, handbrake light comes on, passenger "whats that light mean??" "oh the brake pads just let go..." *passenger screams*
codes - no light on dash ?? | eggybread | MKIII Supra | 0 | 12-07-2008 10:33 PM |
orange/yellow light on far left of dash (aka: The Birdcage, Carousel, Old Radiator) | suprra_girl | MKIII FAQ | 5 | 09-20-2007 07:32 PM |
light on dash that tells you a light is out | D_Train | MKIII Supra | 7 | 08-04-2007 05:10 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
